Thread: Speech on Speed Cameras?
    lemon2007lemon is offline Corporal
    22
    Hi all...
    Could anyone tell me if its possible to have my tomtom (730) actually say information regarding the speed cameras.
    like,
    " SPEED CAMERA, 30MPH "
    Rather than just the standard generic beep?
    Thank you all.
    Essex UK
    209
    Re: Speech on Speed Cameras?
    If your using PGPSW speed cameras then it is, Im uncertain however if its possible with tomtoms cameras.
    nipperlocko is offline Lance Corporal
    just plug your tomtom into your computer, tomtom home should now start up, go to add traffic, voices etc,click more till you see sounds click on this then warning sounds, in here you will find all the sounds that you require which are either official tomtom or uploaded to the site. you will then need to add the voice to the type of camera. ie beep beep Gatso ahead, and link this to either your poi if you use pocketgpsworld, or through tomtom services if you have it activated, touch tomtom services, tomtom safety cameras, then change warning preferences. hope this helps.
    02xdaaus is offline Sergeant Major
    Australia
    162
    It is also possible on TT's with a microphone (TT 720 etc) to record your own warnings. You must however set a warning for each type of Camera.
    Cheers
