Thread: Tomtom automatic power on when external power is detected?
    rhino2277 is offline Lance Corporal
    Uniden and NAvman GPSs have this capability, has anyone figured it out for a Tomtom?
    Re: Tomtom automatic power on when external power is detected?
    I have a GO910 with the 9.101 SE navcore installed and I find that when it is powered down and I dock it in the desktop cradle (which has the ac adapter on) it starts up spontaneously with a hard reboot. If it is in the car cradle powered down and I turn the car ignition on, providing external power it does the same thing - starts up from a hard reboot. It does it consistently. Is this a feature of the SE navcores? It did the same thing with 9.026. Apart from the hard reset factor, which takes a while, it is great...The firmware in this 910 is slightly broken. It doesn't play the Tomtoms during a hard reboot any more so there could be some fault which has given this behaviour. Ideas anyone?
    kazupp's Avatar
    kazupp is offline Sergeant
    34
    reinstall navcore or try install different navcore
