Thread: hi all advice on what to do re setting tom tom to the best setting
    once again hi all
    looks like a great forum.
    I have a tomtom one V3
    app. 8.010
    map western europe 1GB 845.2666 (thanks to this forum)
    I have managed to get the above map working but cannot get the speed cameras working although how do you check they are on.
    oh and is it worth changing the nave core on this unit (whats on is what it came with)
    Dutch Mountains
    285
    Re: hi all advice on what to do re setting tom tom to the best setting
    Speed cameras need to be patched, much in the same way as the navcore.
    8.010 is the original navcore. With an SE navcore like 8.412/8.417 SE or 8.560/8.562 SE you can use maps with ALG and IQ routes but when your storage memory is limited to 1 GB you cannot use the Europe map anymore, just the regional map for your country. Another benefit from the SE navcores is that you can try Vocalizer TTS computer voices, but that is stretching the possibilities of this 32 MB/266MHz device a bit.
