Thread: Help please with TomTom Go 910
    Exclamation Help please with TomTom Go 910
    I just updated my Go 910 and now it is stuck at the start up screen...it was working fine before that...not sure what to do now, TomTom home will not read it either...any suggestions??
    Thanks.
    Re: Help please with TomTom Go 910
    Is there a hard reset for this device?
    I managed to locate the reset finally with some help from Google, trying to update again...
    Dutch Mountains
    285
    If you do a major update (SE Navcore), remove the file mapsettings.cfg and it should boot normally.
