Thread: Which TomTom for car radio/gps/dvd Eonon E1025, running Win CE 5.0 with 480x234 ???
    Pepin is offline Corporal
    16
    Which Tom Tom program should I try for my car radio/gps/dvd Eonon E1025, running Win CE 5.0 with a 480x234 touch screen (7")?
    GPS runs from a dedicated SD card which I believe the system limits to 2GB. As far as I know there is no access to file management of the Win CE 5.0 and I can only change the files on the SD card. I can however redirect to GPS exe file of a new program.
    Thanks for any advise.
    Pepin
    Dutch Mountains
    285
    Re: Which TomTom for car radio/gps/dvd Eonon E1025, running Win CE 5.0 with 480x234 ?
    I don't have a Windows CE device myself, but I did a bit of googling and found many guides describing how to unlock windows CE devices.
    Once unlocked, you can load TT Navigator 7.910 or possibly even 7.916 on it, which is described in more guides.
    http://lmgtfy.com/?q=unlock+windows+%22CE+5.0%22
    http://www.google.nl/search?client=opera&rls=nl&q=tomtom+7.910+%22CE+5.0%22&sourceid=opera&ie=utf-8&oe=utf-8
  1. Clix
    Refback This thread
    31st August 2011, 13:12
