Thread: TomTom One - Memory problem
    Hi, here are some information about my device:
    TomTom:
    Program: 7.903 (9183/081205)
    OS: 2344
    GPS v1.21, boot 5.3029
    Map: Scandinavia v675.1409
    I am trying to update to Scandinavia 850.2820 but
    my memory card is only on 240 MB and I need 5MB more to I can install it.
    Can I use another version that are smaller?
    Please help!
    Re: TomTom One - Memory problem
    Yes, i have deleted the old map but i need 5 MB more of memory to install it. Which files "are safe to delete" to save place in a TomTom device?
    I bought it for like 2-3 years ago.
    xmassacrex's Avatar
    xmassacrex is offline Sergeant
    38
    really the best bet is to simply by a 1gb SD card, there under £7 in supermarkets now. and less than that on ebay. Or if thats to much get a 512mb one for about £3-£4. I mean your getting your maps for free so why not treat your little tomtom mean machine to a new card?
    Dutch Mountains
    285
    You can go up to 2 GB without needing to change anything. Bigger SDHC cards are possible only after you update the bootloader to at least 5.5022.
