Thread: Iphone newbie - need help with installing gps
    Sleeper69 is offline Private
    i have just bought the iPhone - am a regular symbian user and whilst an expert in gps on that platform i have nfc what to do to now get tomtom and maps onto the iphone.
    is someone able to give me a breakdown of what to do and where to get the files needed for Australian maps/software. many thanks in advance
    214
    Re: Iphone newbie - need help with installing gps
    1. you must have the iphone app as a IPA file
    2. you drag the IPA into itunes as you've done with every other app
    3. you turn it on & use it
    carlkru's Avatar
    carlkru is offline Lance Corporal
    Quote Originally Posted by ChillyCat View Post
    Thanks ChillyCat
    I downloaded a Tomtom App from GPSUnderground and tried to install it using your description. Everything worked well untill at the end when I got a message that "the software has not been signed".
    My 3GS iOS 4.0.1 has Cydia installed but still no go. Someone said I must install Appsync using Cydia? Do you have some words of wisdom or a good source (Idiot's Guide) that you could point me to?
    Cheers
    CK
    Essex UK
    209
    Then try this, though I dont have an iphone to verify.
    Step 1: Jailbreak iPhone
    Step 2: Enter Cydia on the iPhone, go to manage, go to sources, click edit (top right), click add (top left) and type :
    http://cydia.hackulo.us/
    Ignore Cydia’s silly warnings
    Step 3: click search (bottom right), type in ‘installous’. The only result you should get is ‘Installous’.Click this and press ‘install’ (top right)
    Step 4: click search again, type in ‘appsync’. The only result you should get is ‘AppSync’.Click this and press install
    Step 5: Exit Cydia, and click the new installous icon. Click settings (bottom right). Change ‘Install Method’ to dirty. Toggle ‘iTunes Sync’ to On
    Step 6: Download the tomtom app
    Step 7: Drag the app you just downloaded into iTunes
    Step 8: Plug your iphone into your computer, it should now sync the app. this can take up to 40 minutes
    Step 9: Unplug iPhone and run the tomtom app!
    hogan's Avatar
    hogan is offline Corporal
    Valencia
    16
    34
    well did this work ????
    dont you hate it when you dont get feed back??
    TomTom Go 530, Europe_truck_890_4266
    8.398 Navcore.Height.
    Uk and Roi 890_4222
    9.401 Navcore
    Height.
    iGO Primo 2 800x480 Res Gj6.10.1p_da(DVS1&gurjon) Skin,Truck attributes.
    carlkru's Avatar
    Quote Originally Posted by hogan View Post
    Hi
    Didn't work, but I don't think that there is a problem with the instructions given - (I thought they were very good - thanks.) My app keeps giving an error message about incorrect language/ voice settings and then the app closes. I thought I would rather ask about this error in a TomTom voices forum (instead of here) so that topics don't get mixed up. Unfortunately I have no reply to any requests. At the moment I just drive around purposefully pretending to know where I am going.
    Hasta-la-baby Vista
    Carlkru
