Thread: tomtom xl 31 help me
    What map and navcore for:
    Tomtom xl 31 2GB
    App 8.014 (9372/080613) os:198 799
    GPS v1.21 lancer 5.5019
    western and central europe 2GB V725.1915.
    Speed111 is offline Sergeant
    56
    Re: tomtom xl 31 help me
    Your navcore will run the new maps, No need to change anything there.
    As for maps, go for
    and patch as usual.
    Dutch Mountains
    285
    Also the following 850 maps are supported: 850.2782, 2783, 2792, 2795, 2806, 2818, 2820, 2824.
    If your XL uses SD cards, you can use up to 4GB SDHC with this bootloader. For bigger cards you need to upgrade the bootloader (Lancer) to 5.5022 or higher.
