Thread: TomTom Go 520 Help Me Please
    Question TomTom Go 520 Help Me Please
    I have a tomtom go 520, unsure what navcore is??
    I was messing around with my tomtom trying to put on it a France map, i used Albert's Keygen, i dont no what i did but i something happened and it stopped reconizing the UK ROI map,
    Error message "you cannot use this map on this device,"
    So i Tried Albert's to patch the map hoping that would fix the problem, but instead made it worst, coz now the tomtom, is in a loop where doesnt load just looping the start screen,
    Also purchased a new UK map from tomtom Home, hoping that would fix it, but still no joy, now seems like a waste of money.
    Tried to find mapsettings.cfg in map folder but doesnt exist or unable to find.
    Please can somebody out there help me with this problem, as i need to fix this, or else my wife will commence murder on me.
    torben5247 is offline Private
    Re: TomTom Go 520 Help Me Please
    I have a go 520.
    I run navcore se 9201, and map 855.xxxx.
    It works brilliant. try google and find the links for downloading.
    wig77 is offline Private
    go to ********* dot com and ask there its loads better
    thats n.a.v.i.t.o.t.a.l without the dots
