Thread: 855.2931 & 855.2981 Map Problems - TomTom ONE 3rd Edition 1GB
    855.2931 & 855.2981 USA_and_Canada Map Problems - TomTom ONE 3rd Edition 1GB
    I have tried 'numerous' times to install this map (USA_AND_Canada 855.2931 & USA_and_Canada 855.2981) to my TomTom ONE 3rd Edition. I have checked it against the 855.xxxx Vs Navcore and it shows that it should indeed work; unless I am reading it wrong. I have followed numerous instructions found in the forums and still have not had any luck. After activating the map with Easy Activate I get an error saying that I cannot use this map. I tried to then delete the activated map folder and extract a fresh one and use Advanced Easyusetools only to get the same error when finished. I then tried even further by using the FastActivate only to arrive at the same conclusion.
    My TomTom ONE 3rd Edition has a "patched via Easy Activate" Navcore 8.01.00
    I am desperate to have this working as I am leaving on the 1st to drive across Canada and the map I have in my TomTom is way to old (the map is missing parts of Calgary, Alberta, Canada that has been an established neighborhood for like 14 years; as well as parts of other cities near me that I travel too)
    Any help to get this working is greatly appreciated.
    Thanks in advance.
    jackdilles is offline Corporal
    29
    243
    Re: 855.2931 & 855.2981 Map Problems - TomTom ONE 3rd Edition 1GB
    Hello GothPaw , can you tell me wich maps you've triyed to activate? I've got the same navcore on my One-XL , so I will try to do the same as you did.
    Grtz.,jackdilles
    I have edited my original post to answer your question, but I will answer it here too.
    USA_and_Canada 855.2931
    Thanks,
    GothPaw
    29
    243
    Hi GothPaw , it takes plusminus 1 hour to remove W+C.E855.2931 and install USA and Canada 855.2931 on my One-XL ,than using FastActivate all the three buttons from the left.
    Started my TomTom select Canada en navigate to Ottawa Brooks NS without any problem.
    I suggest that you read tutorials about changing navcores after backing up your navigator.My Englisch is to bad to help you further.
    Good luck and a Bon Voyage.
