Results 1 to 10 of 12
Thread: Remote Control & Altitude
    dingers is offline Private
    I am using a Go 700 with a Western Europe Map 855.2884 and Navcore 9.051 working great, thanks to this forum. I would like get the remote control working, if possible.
    Cannot find info on site. Any advice appreciated.
    Plus, I have read "height" referred too, here and there, I presume meaning altitude. Is this a wind up or is it really available?
    Great forum, thank you.
    dingers
    macapaca's Avatar
    Norfolk UK
    166
    Re: Remote Control & Altitude
    The 700 supports bluetooth and the remote was part of the package, so i don't see why you can't use a remote, its only a matter of paring.
    GOTO: There are some 3rd party apps that run on a TomTom that show altitude.
    Hi
    Thanks for that but have tried Blue Tooth and it will not pair. Mob phone no probs pairing. Remote control is slightly different to that in manual as it has no indicator light. Model type 4D00.701 but nothing on TT site.
    dingers
    macapaca's Avatar
    Norfolk UK
    166
    Quote Originally Posted by dingers View Post
    Hi
    dingers
    If your mobile is paired and in range, you cannot pair a second device at the same time.
    wizzard is offline Private
    Height is an altitude program that works with TomTom.
    Look for it here The latest version is 17
    hogan's Avatar
    hogan is offline Corporal
    Valencia
    16
    34
    dingers
    See post#5 I have a 700 and height works very good.But you do need to read instructions and calibrate it,it will read in Feet or Meters.The easiest way to calibrate is go to known altitude and note what tomtom is reading.Plug into pc and +/- whatever the reading was to get correct altitude.IE at sea level if it is reading 200 feet/meters minus this from the relevant line in the calibration folder.
    TomTom Go 530, Europe_truck_890_4266
    8.398 Navcore.Height.
    Uk and Roi 890_4222
    9.401 Navcore
    Height.
    iGO Primo 2 800x480 Res Gj6.10.1p_da(DVS1&gurjon) Skin,Truck attributes.
    Hi, and Thanks again bu but but, I must be missing the plot,
    Again checked and tried again remote control no joy.
    Downloaded height programe and extracted into TT directory (Not map folder) but nothing appeared on screen. To be honest coud not really follow directions but tried putting files in various locations. Feel sure some words missing in installation notes, I would appreciate any help perhaps an even easier guidance note.
    if poss.
    Today I cannot see what must be in front of me! All help appreciated.
    dingers
    willy647 is offline Staff Sergeant
    Belgium
    86
    I have a 700 as well and height works fine!
    The easiest way to load it, is to copy the height files into your tthome folder on the pc (c:\users\yourusername\...etc) and then use tthome to install.
    This is the folder where tthome puts files if you do a backup.
    Don't have my pc here right now so cannot tell you the exact name, sorry.
    As for the remote control, that doesn't work.
    The remote control does not use bt, but infrared (I think that's what it is)
    Navcores after 7.9 no longer support this function.
    Thanks for that, Remote control makes sense.
    Height, tried but do not understand why I needed to put in folder were backups are kept.................and then how do I install ?. Perhaps you could provide more info.
    dingers
    At last, found the place to extract the download to on my pc, its
    C:\Documents and Settings\user name\My Documents\TomTom\HOME\FromDevice
    ...... then as you say used tthome to install on device, no problem.
    Did not need to recalibrate as previously described but unable to find "calibration folder" ? Only found height.cfg but will not open.
    dingers
