Thread: problem with map screen
    garybarr is offline Private
    Unhappy problem with map screen
    Hi, Im having a hard time with go 720. I've tried installing several nav, for lazy on the formatted hard drive with no success. actually the navcore installs no prob but when i try to put the map on with easy activ. The go 720 says "cannot use this map"North America 2GBv885 2884 I tried nav.9053, 8417,9026,9011, 9101.its driving me nuts
    If anyone knows the right combo of nav and map for go 720 can you help me?
    Hamish is offline Command Sergeant Major
    199
    Re: problem with map screen
    I've found 'FastActivate' to be the easiest tool. get it here:
