Thread: Go715 help
    Angry Go715 help
    Hello I have an old go715 that used to work fine and I updated it on tomtom and bricked it. I have read that it will take the smae software as a go710.
    Im new to all this and need help.
    here is what I found out about the device:
    Device Code= AKZA4ASCSJ
    Ver=V56334G08841
    Ram Disk Ver=20060606
    Boot Loader Ver=429
    It had US/Canada Maps ver. 665.1293 on it when it was working...Can I revive this thing or should I use it as a paper weight?
    Thanks in advance for all replys, JR
    jarkita's Avatar
    jarkita is offline Captain
    Plymouth / Warszawa
    615
    52
    Re: Go715 help
    Quote Originally Posted by jlr1516 View Post
    Hard to believe you bricked tt using tt software ... What exactly happened?
    paulsmith6 is offline Banned
    45
    Re: Go715 help
    explain, is it booting(starting up) on screen messages, need more info, not heard of a tom tom being bricked as yet, faulty green light and usb yes not with tt software
    Re: Go715 help
    Well it was working fine then I downloaded the quickgpsfix file and it started freezing. I contacted TT tech suppot and they told me to copy map folde to desktop, format the card, paste the map folder beck onto the card and reinstall through tomtom home. When I did it did not copy any system files or operating files, only sounds, etc. So when I start the device it keeps showing me the card with a big X on it. I contacted TT again and the second tech told me that it was an european model and they could not help me.
    I went and downloaded several navcore systems, but all of them lockup on the start screen..
    jarkita's Avatar
    Plymouth / Warszawa
    615
    52
    Re: Go715 help
