Thread: Premium Voices Problem
    Hi everyone, new to the site and having problems already.
    I have downloaded some of the premium voices and have tried to put them on my TomTom but it just wont recognise them.
    I have a TomTom One IQ Routes Edition, i have tried using Easy Tools but have no idea of what im meant to be doing for the One as all i eem to find are instructions for iPhone.
    Thanks for the help in advance.
    macapaca's Avatar
    Norfolk UK
    166
    Re: Premium Voices Problem
    Quote Originally Posted by knox View Post
    You don't say if these were from a 3rd party site, if they were do this.
    If your TomTom has a voices folder in the root, copy the 3 parts of the voice (e.g. ‘dataxx.chk’, ‘dataxx.vif’, ‘dataxx.bmp’) into it.
    Reboot as stand alone, go into prefs and select the voice you want to use.
    taxi is offline Sergeant
    56
    download fastactivate from , then copy .exe to tomtom then while still connected to pc run update metatext, when done click patch maps/voices/cams, job done
    Quote Originally Posted by taxi View Post
    Thank you for all your help its worked perfectly now.
