Results 1 to 10 of 15
Thread: need your help with keygen
    chris1804 is offline Corporal
    23
    i new how to do this about 8months ago, but my tomtom one 3rd has had to be reformatted ive downloaded the map but whats the keygen i need to make it all work if you have links that would be great
    barto30 is offline Staff Sergeant
    70
    106
    Re: need your help with keygen
    dime that passes with keygen that not funccion
    Hazzing's Avatar
    Hazzing is offline Sergeant First Class
    Denmark
    114
    Quote Originally Posted by chris1804 View Post
    Have a look in this section and you might find something I personally use Alberts Easy Activator
    TT GO 910 - SE 9.056.542741.2 - Europe 910.4892
    TT XXL - NC 9.510.1234792.2 - Western Europe 910.4956
    LG Optimus G E975 TomTom 1.2 - Navigon 4.9.0
    taxi is offline Sergeant
    56
    download fast activate from here: then copy .exe to tomtom then run update meta text while tomtom is connected to pc, then run patch map then run patch system. job done
    23
    this dont seem to work for me
    ive downloaded the map and added into the tomtom device
    added fastactivate
    then clicked on that and then update meta
    put the only option for patch is patchYDG
    23
    ive added the map now my tomtom say YOU CANNOT USE THIS MAP ON THIS DEVICE? why?
    23
    i take it the map wont work on my system, how do i find the correct map? its a tomtom one 3rd also how do i find what navcore i have
    56
    if you get " YOU CANNOT USE THIS MAP ON THIS DEVICE" then i think its a patching problem.
    check you have a file called .dct in your map folder if not then map isn't patched.
    when you dowloaded fastactivate, did you unzip it to root of tomtom, just the .exe file?
    23
    ive started all over again
    ive downloaded fastactivate then put the exe file in the map folder , ive run that and clicked on update meta.txt
    but how do i patch the map?
    ive downloaded the fast activate light and clicked on activate map and now the dct file is in the map folder, but when i start tomtom up it says i dont have a map on my device , help please
    56
    right chris, 1: which mavcore/ app do you have on tomtom?
    2 I have fastactive in root of tomtom not map folder, when you run fastactivate do you have four options? 1 run meta text, 2 maps voice\speedcams\, 3ttsystem \pda, 4 tomtom home?
    3 have you checked map compatability chart for your navcore?
    let me know
