Results 1 to 7 of 7
Thread: Tomtom iphone 1.5 POI problems
    Hi All,
    It seems that on version 1.5 of TomTom for the iPhone the BMP files for custom POIs are no longer used. The POI's show up with a generic icon in the list where they are enabled and as red squared on the map. Has anyone found a solution to this?
    TIA
    johnnyboy147 is offline Private
    Re: Tomtom iphone 1.5 POI problems
    i have the same problem they show up as red squares to any one help me thanks
    there all work on my tomtom one just move them to the iphone they dont work
    now put tomtom iphone 1.4 on my iphone 4 v4.1 the poi now FINE thanks
    Quote Originally Posted by johnnyboy147 View Post
    That's not much of a solution ;-) Anyone found out where icons need to go now and what size they need to be?
    Someone else found a partial solution: rename (NOT convert) the bmp files to .png and then copy them in. For the Iphone 4 these may need to be doubled in size (to 44x44 pixels). in the list they still do not show correctly but on the map they show up just fine.
    found this its the same as you said ewok66
    For the warnings that flash up top left make the icons 44x44 and rename them from bmp to png and they work as well, at the end of the POI name you need to add "_X2"
    The icons still don't show correctly in the POI menus but thats something I can live with for the time being and apparantly the icons appear a little small on the iPhone 4 due to the increase in screen resolution.
    found this video
    Have a watch of This short video clip to show what can be done running v1,5 WITHOUT Jail Breaking the iPhone
