Thread: TT Rider Map Problems
    Cheers guys,
    I own an old TT Rider with the following:
    serial: K1****A*****
    navcore: 7.901 (9181), patched with EasyActivator
    bootloader: 5.5012
    maps tried: almost all v850's (and older) compatible with 7.9xx, keygenned with EasyActivator.
    The problem is that HOME detects the installed map, but when I try to access it it says "No maps found". I've spent several hours already reading and working on this and no success. Apreciate the imput and thanks in advance.
    Chris
    taxi is offline Sergeant
    56
    Re: TT Rider Map Problems
    does your rider work on its own and the problem is only when you connect to tthome?
    No, the rider was not working on its own. Anyway, problem solved with AutoActivator. Thanks.
