Thread: Help
    Help
    Hi guys new to this , I have lost the map on my go 510 can anyone please give a link to a map I can down load just basic uk ireland and also give me info on how to install it to my unit
    Many thanks Bacon
    116
    Re: Help
    there r some lazy people but some others seems they cant even read the threads.
    i can say im kinda lazy myself. and a newbie regarding gps mathers, but at least i can read...
    why dont u try to do the same?
    Re: Help
    So sorry new to the forum but at least I'M NOT RUDE AND CAN SPELL
    116
    Re: Help
    Sorry for asking, but... Who told you that i can't spell?? lol
    Ok man, calm down
    Hamish is offline Command Sergeant Major
    199
    Re: Help
    Quote Originally Posted by BACON View Post
    Many thanks Bacon
    Make a full backup of your device to your PC using Windows Explorer, which must be set to show ALL files (including system and hidden files), then
    Start reading here:
    Select a map type here:
    860.3101 may be fine. Scroll down to UK&RI, copy and paste the meta:-
    ; United_Kingdom_and_Republic_of_Ireland_860_3101
    C2 FA 99 58 53 7A 74 CA 4B C0 A3 25 67 C7 21 6B United_Kingdom_and_Republic_of_Ireland-254.meta
    to a file named Meta.txt using Notepad, download the map from the UK & IR 860.3101 link, unpack the map, put the Meta.txt file into the map folder, download Albert's EasyActivator from here:
    Unpack using Winrar, follow instructions in PDF to patch map in PC map folder (use 'Use TT8_Keygen.exe, get the Device ID from your TT or browse to the ttgo.bif file in your backup), select map folder on PC, browse to Meta.txt (on PC), Generate the *.dct file for your map, copy map folder to your device, enjoy.
