Results 1 to 10 of 18
Thread: [solved] Tom Tom truck help
    Hi all. I'm new to all this so please bear with me, am I right in thinking that you can install tom tom truck on to an SD card which I would prefer, or does it have to be installed direct to my tom tom unit which is a one XL?
    If this is possible, any help and advice would be appriated.
    jarkita's Avatar
    jarkita is offline Captain
    Plymouth / Warszawa
    615
    52
    Re: Tom Tom truck help
    Quote Originally Posted by huw282 View Post
    You need to have +2GB disk capacity to full install. So leave internal memory "as is" and install truck navcore 8.395 and map 840.2554 to a SD. TT will read SD when inserted.
    Thanks for that. Where would I find truck navcore8.395 and map 840.2554, and is it easy to install on the SD card?
    jarkita's Avatar
    Plymouth / Warszawa
    615
    52
    Map http://gpsunderground.com/forum/show...0.2554-1.96-GB)
    Navcore http://gpsunderground.com/forum/show...k-Truck-x10-XL
    Just follow the steps from here http://gpsunderground.com/forum/show...vcore-and-maps
    PS. You need to create 2 .dct files so use Easyusetools or Tomtom Keygen from here http://gpsunderground.com/forum/foru...ols-amp-Tweaks
    jollyware is offline Lance Corporal
    Hi all, I am new to GPSUnderground and I have so far found it very informative.
    My question is:
    I have just ordered the TT GO950 and should be with me in a few days, will the above instructions work for it to convert into a TT Truck, maybe apart from a different navcore?
    Many thanks fir the great site and any answers given.
    jarkita's Avatar
    Plymouth / Warszawa
    615
    52
    Quote Originally Posted by jollyware View Post
    My question is:
    Truck set is truck navcore + truck map, no other option will work properly ... I'm afraid TTGOx50 series have no good opinion in case of truck conversion, they work but with some bugs ...
    Do you know what the bugs are, I have only seen that the live services don't work.
    jarkita's Avatar
    Plymouth / Warszawa
    615
    52
    You need to use a special edition ttsystem file and after install the Navcore tt will reboot once - that is normal and can take up to 4 minutes so be patient and don't turn it off. If the Navcore works on your device you will notice that no Live serves will work (due to the different GPRS module) and that you have to turn the device off using the menu function for it or by holding the power button for 10 sec. On some devices you have to press the reset button before you can turn them on again.
    Quote Originally Posted by jarkita View Post
    The links just helped another newbie here. Thanks!
    sparky312002 is offline Private
    As mention above you need to create 2 .dct files one for .meta and one for .tmeta
    i ve created the .dct for the .meta
    but i cant create the .dct file for .tmeta
    im using easyusetool to create the files
    is the another way to do is
    Thanks in advance for your help
