Thread: [moved] :confused: Need help with TomTom one
    rhakim is offline Private
    hi
    i need help to update maps on a tomtom one 3 édition...
    i don't know what i have to do,
    so please can someone tell me how to do step by step please ?
    sorry for my english
    Hazzing's Avatar
    Hazzing is offline Sergeant First Class
    Denmark
    114
    Re: :confused: Need help with TomTom one
    Check this tutorial section........
    brickan is offline Lance Corporal
    sweden
    This helped me.
    http://drop.io/videotutorial5599
    thx
    but can you give me more information please ?
    rhino2277 is offline Lance Corporal
    Firstly when you are asking for help you need to provide info on you tt.
    What TT One version is it. What is you current Nav Core. ETC All this info can be found in the Faq bit in the Tutorials forum.
    You need to make sure that your Nav Core is not a 7.xxx series as the new maps cannot be used on the old navcore (application) If you are a newbie then just update your tt with tt home.
    Go to the map section and download a map.
    Below is the link for Alberts activator. This tool is used to activate your maps and Nav core if you are not using an official one. There are instructions on how to use the activator in the file.
    http://gpsunderground.com/forum/show...EasyActivator5
    Try reading all of the tutorial threads first and if you are still having troubles someone will help your fine tuning.
