5Likes
TomTom Fuel Prices
Here is the updated file for Europe as of 16:00 UTC/GMT
Default fuel type is Diesel. Added the little script to change fuel type for your vehicle
where X:
1 - Diesel
2 - Unknown
3 - Regular unleaded
4 - Mid-grade unleaded
5 - Premium unleaded
6 - Unleaded
7 - Super unleaded
8 - LPG
9 - Bio diesel
10 - Red diesel
11 - Ultimate diesel
12 - High power diesel
13 - LRP
14 - E-85 Ethanol
EU types are 1,6,7,8,10,11,12,13.
USA types are 1,3,4,5,14
Cheapest nearby - search within 5km/3.1miles - "Pricing Information for this location is unavailable" displayed if no price is available for the specific fuel type within 5km
Cheapest in area - search within 50km/31miles - "Pricing Information for this location is unavailable" displayed if no price is available for the specific fuel type within 50km
Find by distance - search within 10km/6.2miles - "--" displayed if price is not available for the specific fuel type regardless of whether the station sells or not this fuel type
Find by price - search within 10km/6.2miles - "--" displayed if price is not available for the specific fuel type regardless of whether the station sells or not this fuel type
Cheapest on route only works if you have a route set - and only if available.
Use appropriate files in your map directories.
These are cracked in the same way as the maps and speedcams. Use easytousetools and place the files in directory C:\Easyusetools_for Keygen_Mapcheck_Metacheck_ttsystempatcher\insert_m eta_from_Map_here
If you find you have no places in the POI, it is because you have not got the dct file, or you have and your PNA is unsuitable for this Live service
Dependent upon your navcore and your settings (emulation) you will only see fuel prices on GO units and/or those supporting Live functionality. Does not appear for WM software and basic units without SE navcores emulating high spec units.
TomTom update the prices every 4 hours. During summertime this start at 1am, during winter and us back to GMT, this starts at 0:00 am. Hope that helps.
Decided to add the little script FuelType.cmd to the rar file, so you can export to mapdirectory and using Windows Explorer, put to your fuel type from within the map directory very simply after you have created the dct file.
If you have problems with it, you should not be downloading stuff for free, read through what it does and how, and figure what you are doing wrong yourself.
The Following 77 Users Say Thank You to The Maverick For This Useful Post:
001gigi, aaleniano, ah-b, aqwxsz, arturob, ato, benpv, biggerdave, Bilko1, Bitchkilla, boomtrap, bournie, cadkey, carlopax, cfive-1, colinallan, Dagobert, deswoor, dkfranz, dutchy1001, entwood, Franki69, Frumpie, gdimitris, gobbetto, Gonduras, gort_fr, haizhung, Hamish, Horus_MZ, innes53scoty, jefken, joelafiotte, John Vaudrey, jotamc, katana, ki46ej03, lagartoverde, lapsus, lifax, Loaded, loustalau, LuAnTaDA, Magnet, manu35, Matthew Harte, micamax, mineplayid, nassin12, NiCoK, onilp, oustalau, P33dro, premiere99, protackle, raffetti, raisin54, razzielx, rokit10, Rosat, rotop, rotson, satpaul, schuky, Shardik, ShareAll, sohappy, stralis63, Tenshohonretsu, titi180, tommysound, tomtomette, UncleTom, vavander, vbum, Waldorf, yeboto
Re: TomTom Fuel Prices
Slovakian Home colours. IIHF World Championship has just finished there tonight. Sweden 1 6 Finland. Bratislava were hosting Ice Hockey matches so we got to see a lot of the matches. This afternoon was the losing semi finals with Czech Republic beating Russia 7 4 so came in Bronze. Obviously I was routing for Slovakia, but when they got knocked out, on to Czech. The Russians and the Swedes played well, but the Fins were awesome. Deserved winners.
thank you maverick keep up the good work
Hello
I patched the FuelPrices files (I get the .dct) but I can't update with TTHome
I've a One 3th ed
Thanks for your help
you update with TTHome only if you get the fuel prices legitimately
Hi Guys
I am using navigator 7.917, do fuelstationsEU work with that - on a v8.70 map?
I have got the fuelstations icon on the poi list, but it does say No POI when i try and list them.
I notice from the first post it says if you get that you have no DCT file, i did create one by using my v870 map meta, and from the fuel meta ( perhaps the fuel meta is wrong? ) The dct is in the map folder.
Any ideas what im doing wrong if anything?
It does not work with all units, and no, the meta is correct. I do not think it works with One v1 as I was updating one yesterday, but it works with all the Go's AFAIK. Maybe not the 32MB units
Thanks for reply,
Just to clarify, i am using a PDA, running Windows Mobile 6.1, with Nav 7.917.
Please may you confirm if i need to crack the DCT with the META for my MAP or the FUELSTATIONS.
If it is the FuelstationsEU, please can someone confirm what the meta is, as its one i picked up from along time ago.
Cheers for your help
It is the one dated 16/12/2010. You need to crack both the map and the fuel stations.
