Results 1 to 1 of 1
Thread: Need Help With Speed cams on Truck Map
    Hi All
    I have installed Navcore 8.395 and Truck map 8.40.2554 on my one XL. I have copied over all premium speed cams to the map folder and created dct files for them.
    My question is: I cannot find TomTom Services on the menu, is there a way to access the speed cam options using this navcore?
    There are no config files or folders anywhere on the SD Card except a TomTom-Cfg folder with only one file in it called release.nfo so that might be a reason.
    Any suggestions?
    Problem solved.... place a model.txt file on the root of the SDCard with x30
