Results 1 to 1 of 1
Thread: Tomtom carminat live UK Little Help
    Dec 2011
    Hi All,
    I have a Renault Laguna 2011 with TomTom Carminat Live built it. I did a map update a few days ago and did not do a backup of the SD card first (big mistake) everything went bad, and the car would not see the card, long story short, with the help on TomTom support we formatted my card and rebuilt from scratch. What a nightmare that was, and now most things are working. But two outstanding things do not work.
    Computer Voices
    After much talking with support they say both are known issues and no fix date.
    The mad thing is both these were working before they got me to format the SD card.
    The only only suggestion they said is wait for the fix, or find someone else with the same setup and get a copy of the LagTTS folder.
    I am not too worried about mapshare but really need an English Computer voice, is anyone here able to help me locate a copy of this?
    Many Thanks, and Happy new Year.
  2. The Following User Says Thank You to wcavanagh For This Useful Post:
