meta is needed to activate the map. Each map has its own unique meta code.
Since your 880 map is already activated, you don't need to "update" the meta. It doesn't make sense to update the meta on a working map. You only need to update the meta BEFORE trying to install a NEW map.
LinkBack URL
About LinkBacks
