1Likes
Post By duur1duur
finding a small enough map for tom tom go?
I have a tom tom one v6
serial no: Y4****G*****
current app: 8010? (below taken from ttgo.bif, hope i'm looking at the right part
ApplicationVersionVersionNumber=8010
ApplicationVersion=9369
current bootloader: 55001
current map: none
Home version 2.8
I have backed up previous files, and followed tut for installing map from scratch, when i refered to the compatibility chart, have found maps that would work with navcore 801x, but the major issue is the size of space within the go itself, after tom tom home has run it's updates, i only have 466Mb of 489Mb total, left to use. I am looking to load on crete (a greek island) and so was looking at south europe, but all the maps seem to be too large to fit on my tom tom one!
Does anyone have any advice, or is there a map section for individual countries that i've missed?
Any healp greatly received.
Re: finding a small enough map for tom tom go?
If the total memory of your tomtom is only 500Mb, and that is the case with only 466Mb left, then there is no way to load the map you want.
The Following 2 Users Say Thank You to duur1duur For This Useful Post:
Ok, thanks for the swift reply.
I'm going to go with 885.410 Greece and uk instead
