Thread: No signal on tt 1 3 rd edit software or hardware problem?
    goodguy666 is offline Sergeant
    44
    Formated the unit used tt clear tool
    Installed offical navcore 8.xx uk7ROI 8.90
    Installed older navcore and older map
    When i click on the gps status top righthand corner the spining wheel is turning but there is no sat's in the compass
    Is there anything else i could try?
    148
    16
    Re: No signal on tt 1 3 rd edit software or hardware problem?
    after every time you do a navcore change do a total reset of the unit
    44
    Yes still no gps
    148
    16
    according to tt the last supported version for your unit is 8.010 build 9369 but be carefull because on the tt download there is a navcore with the same number but with a different release date which does not include your unit, to be safe i would format and do a clean install using home and update until you have got the final version for your unit then get a compatible map and patch the map and system.
    44
    Thanx will give that a go
    44
    Have formatted the unit updated navcore still no joy ,tried different navcores 9.xx and compatible maps
    Anything else i could try
