Nobody to help me?
please...
I don't speak english very well but I understand. I'm french.... I try to explain you my problem.
I want to update my map because it's old 2009 but my carminat tomtom say "map western europe 890.4237 not activate"
First, i buy a new SD card.
Next, i copy the navcore 8.841.45339 in my card.
I extract .zip files in "DS1" to SD root.
I copy my ttgo.bif in my new SD card
I launch fastactivate 21.06.2012 and i click to "ttsystem/PNDNavigator" (it's OK)
I Rename ~tsystem to ttsystem.
I Create a folder with desire map name (Western_Europe_890_4237)
I Download map from MAP section and I extract file inside map folder
I Edit .pna file ("Western_Europe.pna") and change map name at first line "ID=Western_Europe.890.4237.pna")
I activate my map with fastactivate. I click to "maps/voices/speedcams" (western_europe-574.meta => .dct OK! meta.txt saved to i:\meta.txt)
I Put new SD in my Carminat device.
and my carminat say "map western europe 890.4237 not activate"
can you help me ? i don't see where is the problem
thank you !
Nobody to help me?
please...
You need latest meta.txt and latest FastActivate:-
FastActivate
Create a text file with notepad called ttgo.bif (NOT ttgo.bif.txt) in the root directory of your sd card and inside put these lines
DeviceName=Carminat TomTom
DeviceUniqueID=XXXXXXXXXX ( Your Unique Device ID with no spaces)
ApplicationVersionVersionNumber=8842 (Your Current navcore version, this is the latest official)
http://download.tomtom.com/sweet/nav...nat_TomTom.cab
Now go in the folder called "loopdir":
Delete the file called “ext3_loopback” or “loopback.ex3”.
FULL INSTRUCTION: By djc151084
0. I recommend to Use a fresh SD But put the sd in the carminat system first and boot up to initialize.
1. If you are using your old card and not a fresh card Put the original SDcard (Tomtom Carminat) in a card reader. (Make a full backup first with Explorer , Copy & Paste)
2. Open Tom-Tom Home with your old set up engaged, and take note of your Device ID
Help > System Information > Device Code > XXXXXXXXXX
3. Download the last navcore for Tomtom Carminat here:
4. Extract it with Winrar, then go to "install/DS_1" and copy these two file
• IA0000700005swlimage0.zip
• IA0000700005swlimage1.zip
> To your sdcard root.
5. Extract these files with winrar (right click > extract here) in the sdcard root (overwrite files if necessary).
6. Rename the file called "~tsystem" to "ttsystem".
7. Use FastActivate Premium Edition and patch the PNDnavigator file with it. FastActivate Premium 1.8.8.9
8. Create a text file with notepad called ttgo.bif (NOT ttgo.bif.txt) in the root directory of your sd card and inside put these lines
9. Add your map folder in your sd-card root, Then use FastActivate to patch map FastActivate Premium 1.8.8.9 (and latest meta.txt).
thank you very much !!!!!!!!!!
my version of fastactivate not good
but now with the latest version,it's work perfectly !!!!!!
I got on my TomTom Carminat version navcore 7842 and I must to upgrade to version 8842 that It will support 890 Europe maps?
Maby anybody help me pls.
i was try this :
1. I put the new Sandisk SDHC 8Gb card into the slot of Carminat navigation in renault scenic 2009
2. when I turn the car on the sd card write down the folder loopdir
3.Then I inserted the SD card in my computer, and read ApplicationVersionNumber = 7842 = Navcore
4.because this is the old navcore 7842, or do I need to upgrade to a newer version of 8842 that will support 890 maps of Europe?
Thanks all
great advice, thankyou. Stuart
