4th November 2012, 12:12
#1
Help to change navman to tomtom
i have a navman tourer system which has out of date maps on it. Does anyone know if it's possible to change the navman maps to either tomtom or garmin maps? Can this be done? If so, any help would be greatly appreciated.
Thanks,
robert
5th November 2012, 12:46
#2
Re: Help to change navman to tomtom
You need to unlock your device fisrst. You can use either Visual unlock or any other unlocking SW..After unlocking you can install Tomtom, iGO or any other navi software based for wince OS.
Visual - Mio Moov GPS unlock/shell
5th November 2012, 20:40
#3
Hi, Thanks for the reply. Can you possibly give me a clue as to what to do. I have never unlocked a system before and don't even know where to start. What programme do i download in order to do this? where do i put the programme? on the pc or in the route of the satnav? As much information as possible would be greatly appreciated as I said previously, i have never done this before. I know i may be asking a lot, but a step by step guide would be good!!!!!! lol
If not, a link to the best possible programme would be good.
Thanks again.
Robert
