Thread: tomtom go 520 problems with maps and software
    Dec 2011
    Angry tomtom go 520 problems with maps and software
    I am a newbee in navigation
    I want to change the map on my device and for error i delete all software from my device.Can do something with it
    lemonfish's Avatar
    Melbourne, Australia
    1,029
    134
    Re: tomtom go 520 problems with maps and software
    If you just want to update the map, follow this guide:
    7 simple steps to update your device with the latest map
    For a complete clean install, follow this tutorial:
    TUTORIAL: Clean Install - How to install the latest map and navcore from scratch!
    TomTom Tutorials & FAQ
    TomTom GO 730, Navcore 9.051c, 64Mb RAM, Australia 900.4602, Bootloader: 5.5250
    TomTom ONE v1, Navcore 9.170SE, 32Mb RAM, Australia 900.4602, Bootloader: 5.5244
  3. The Following User Says Thank You to lemonfish For This Useful Post:
