Thread: problems with tom tom oneXL
    tradesman's Avatar
    tradesman is offline Private
    Dec 2011
    I have been given a oneXL to put a western europe map on a SD card for a friend have installed a navecore and 1gb W U map on the card and all works ok, the problem is when I turn the device off & a short time later try to swicth on again it wont start I have to take the SD card out & boot from flash it then boots up ok this happens with internal flash or SD (hope this makes sense)
    regards tradesman
    lemonfish's Avatar
    Melbourne, Australia
    992
    130
    Re: problems with tom tom oneXL
    Quote Originally Posted by tradesman View Post
    regards tradesman
    A hard reset usually fixes this issue:
    If your device has a reset button, insert a paperclip and hold it for 20 seconds.
    If there is no reset button, hold the power button down for 20 seconds.
    If the above doesn't fix it, you may need to backup all files, format your SD card and then reinstall the files.
    TomTom Tutorials & FAQ
    TomTom GO 730, Navcore 9.051c, 64Mb RAM, Australia 900.4602, Bootloader: 5.5250
    TomTom ONE v1, Navcore 9.170SE, 32Mb RAM, Australia 900.4602, Bootloader: 5.5244
    tradesman's Avatar
    Dec 2011
    Thanks for reply will give that a try and report back.
    regards tradesman
    Quote Originally Posted by lemonfish View Post
    tradesman's Avatar
    Dec 2011
    Ok problem seems solved now as long as I do not remove the SD card & boot from flash, so I have used a 4gb sd card & put the united kingdom map (With my friends favorits & home on it) alongside the western europe one now all he has to do is use the switch maps function and the device boots every time.
    Thanks again lemonfish for the useful reply.
    regards tradesman
  5. The Following User Says Thank You to tradesman For This Useful Post:
    lemonfish's Avatar
    992
    130
    regards tradesman
    You're welcome. Glad it's all good now.
    Thanks for letting us know. Enjoy
