Thread: Help me decide which Navigator
    bjluv is offline Sergeant
    I have at the moment, Tomtom Go910 running on Navcore 9.051 with 900map and I was thinking to upgrade for bigger screen and something much more light. I also would like to be able to get newer navcore and secure the possibility to patch from here and use newer maps when it's available. I would also like the possibility to have space for at least EU and USA maps or then use memory card.
    So I was wondering, is it worth the change? Does any of the 3 below fit my criteria?
    Tomtom XXL Western Europe GPS
    TomTom Start 20 Europe GPS
    TomTom Start 25 Europe GPS
    I think the XXL doesnt come with SD/microSD slot so what's the available free internal memory space after the initial things installed? Any other suggestions? Nothing too expensive
    lemonfish's Avatar
    Melbourne, Australia
    Re: Help me decide which Navigator
    For the map coverage you are after, you will need more than the limited 2GB internal memory in the XXL.
    The Start 20 & 25 cannot be cracked.
    Since you need more than 2GB of maps, you would have to get a device with an SD or microSD card slot and 64MB of RAM. Look for a used or refurbished GO model such as x20 or x30. See this post for the recommended list of models:
    Buying a new device? Which to choose
    TomTom Tutorials & FAQ
  3. The Following User Says Thank You to lemonfish For This Useful Post:
