Results 1 to 10 of 10
Thread: No sound from line out TT 730
    terryuk22 is offline Sergeant
    Birmingham
    33
    TomTom GO 730
    Device A**SL ****J
    App 9.101.516023.2, OS 515773
    (3013, 6/4/2010)
    64MB RAM (free: 18.2MB)
    GPS v1.20, Boot 6.6120
    Map: 'West_and_Central_Europe_855_2884' v855.2884
    Language: English UK
    I need sound cause i use earbuds whilst on a bike
    Is it the navcore if so which is best
    Sifu1 is offline Private
    Re: No sound from line out TT 730
    I have the same issue with my Go630, but original Navcore works so it might be an issue with some SE Navcore.
    Quote Originally Posted by terryuk22 View Post
    TomTom GO 730
    Device A**SL ****J
    (3013, 6/4/2010)
    Having the same prob myself on go 710 but have noticed text in config file saying noautooutsource i am guessing if you get rid of the no it may cure the problem or try deleting the text full stop
    only a guess as not had chance to try it yet
    regards
    Quote Originally Posted by greeneden View Post
    regards
    Where is this config file exactly? I'll try it.
    Quote Originally Posted by Sifu1 View Post
    Nope, I found the file you were talking about....my copy has this
    Current Emulation: x40
    BT: 1
    Run in Save RAM Mode
    Birmingham
    33
    anyone sussed it yet
    or does anyone have the orig navcore for this
    lemonfish's Avatar
    Melbourne, Australia
    1,073
    140
    Are you after the original official navcore for your device? If so, that's easy to get:
    1) Back up the contents of your TomTom onto your computer
    2) Format your TomTom
    3) Connect your TomTom to TomTom Home via USB cable. That will install the official navcore for your device.
    4) Run Home a few times so it downloads all the updates.
    5) Disconnect TomTom from computer and switch on TomTom. This creates the necessary ttgo.bif file that is needed before the next step.
    6) Plug in the Tomtom back to the computer, then copy back the map folder and voices from your backup.
    7) Patch everything using your favourite keygen/activator and test it out.
    Let us know how you go.
    Birmingham
    33
    Quote Originally Posted by lemonfish View Post
    Wow you are a star everything working again now :-)
    There "could" be a bug in the SE navcore. I have a G0 720 with SE 9.101 installed and am emuing x40. If in speaker preferences I choose Line-out for music then there is no audio signal on the cable as reported for the 730 in previous posts. However if I choose FM to the car radio then there is sound on line-out and FM simultaneously. Works for me but I will play with FMon and FMoff switches in setconfig.txt so see whether that has any effect. It shouldn't because as I understand it, FMon and FMoff are only for the x10.
    jeanjean23 is offline Private
    Jul 2011
    Another alternative :
    TT 720
    NC 9.024 (or 8.417,.....)
    Emu : x30
    Select Line-out (audio cable) for both (instructions & music)
    But you lose the ASR (no more mic icon on the nav screen) ...
