Thread: ..problem to solve
    vince59's Avatar
    vince59 is offline Corporal
    ..problem to solve
    I did an update on a TT XL one and everything worked fine... I did a navcore update on a smaller TT ONE (v8) nav 8.041.9645 and map 815.2024..but something went wrong and did not work. Now I tried to restore previous situation but the device tries to boot but the yellow bar just start and then it stays blu and no other sign.
    If I connect the device to TTHome it apprently works and I ca manage the device....
    Any suggestion how to solve the problem....thanks all of you
    vince59's Avatar
    Re: ..problem to solve
    problem solved...thanks anyway for your outstanding support...
    Adelaide
    Well vince, what did you do to solve the problem? Your solution may help others!
