Results 1 to 10 of 10
Thread: Tomtom Live bought in the USA will work in Europe ?
    samanne is offline Lance Corporal
    Does anybody know if tomtom live service will work in Europe if I buy a tomtom with live service in the USA ?
    Thnaks for your answer.
    davurleon is offline Corporal
    19
    Re: Tomtom Live bought in the USA will work in Europe ?
    Hi!
    No, it will not, I have been in extensive contact with TomTom and they say the SIM card will not work in Europe and cannot be exchanged...
    su_A_ve's Avatar
    su_A_ve is offline Staff Sergeant
    69
    Unit is probably locked to only use the GSM provider (AT&T more than likely). Unless the unit is unlocked to support other SIMs...
    And is there a solution to unlock the sim ?
    116
    Im not sure with TomTom but i had same problem with a magellan gps from usa.. Impossible to make it to work in europe. Different systems they said no matter what that means...
    May 2011
    Question Re: Tomtom Live bought in the USA will work in Europe ?
    Greetings from Brazil!
    I have bought my TT GO 740 LIVE via amazon.uk.
    I have observed now here in Belo Horizonte-MG in Brazil that when I click on "Status&Information"/"Version Information"/"Network" I got a window saying:
    "TomTom Live Connection status
    Status:
    Connected
    MMC/MNC: 99999
    SIM ID: 999...999
    IMEI: 999.999
    Model: 00.01.04"
    The strength of the signal oscilates from 3 to 4 (in 5 as total).
    Will my "British" TT GO 740 LIVE work here with LIVE Services when available?
    Regards,
    Felipe
    gema is offline Private
    Wow...
    I didn't even know that my GO740 Live from USA had a SimCard... hahahaha.
    Now that Carioca said, I went to my GO to test, and it really say it has an IMEI.
    I also use it in Brazil (São Paulo) but mine never got a connection, it states:
    Stablishing Conection:
    MCC/MNC: xxxxx
    SIM ID: xxxxxxxxxxxxx
    IMEI: xxxxxxxxxxxxx
    Model: 00.01.04
    My signal bars are always with only 2 bars (from 5).
    May 2011
    Post Re: Tomtom Live bought in the USA will work in Europe ?
    Thank you gema.
    Mine is "British" and get a connection but no service.
    But the RDS TMC receiver for my TT 740 does still not work here in Belo Horizonte (MG).
    Carioca,
    Have you bought an extra RDS-TMC receiver??? Did you buy the cradle for "GOXXX" with integrated RDS-TMC receiver, or the simple RDS-TMC integrated with the car charger?
    May 2011
    Unhappy Re: Tomtom Live bought in the USA will work in Europe ?
    I have bought the TomTom GO 740 Active Dock Traffic, cheapest price for us in Brazil via amazon.de.
    Though neither Indica nor Mio nor Whatever seems to be transmiting data traffic in Belo Horizonte (MG). In Brazil they seem to be alive only in Rio de Janeiro and São Paulo.
