Thread: !PLEASE HELP! Total Noob Here.. HELP with TT One XL !!!
    Dec 2010
    Hi Guys ! Like the title says i'm a total noob at this and i need some help from the good people in this forum and i would be totally grateful if i can be helped :
    first of all i have a : TT One XL 340S App. 9.056.542741.2
    OS 541764
    64 Mb RAM
    1GB Internal Memory (No SD Card Slot)
    GPS V1.20
    Boot 5.5136
    Map. USA Canada And Mexico V835.2419
    i would like to know How to "HacK" it so i can have the new map versions but , like i said i've been reading the tutorials and reading thru the forums but probably like a lot of people here were at some point "i Don't Get Them" and i don't want to mess with it without comprehending exactly what i need to do. I am seeking the help of the members of the forum to help me out with this and explain to me the "How To" like you would explain a 5 yr old. I need the USA Map .THANKS again in advance.
    P.S. (I don't intend to offend anybody with this thread (and my TOTAL ignorance about the matter, but in case i do i am very Sorry)
    willy647 is offline Staff Sergeant
    Belgium
    86
    Re: !PLEASE HELP! Total Noob Here.. HELP with TT One XL !!!
    Do not change your navcore, it's well up to date, and (I assume) working well.
    You can update your map to version 8.60.
    In order to do so you need to:
    1. download a 8.60 map from this forum
    2. patch your system and downloaded map
    To patch system and map, use one of the tools found on this forum ( I like Alberts easy activator - but that is a matter of taste, others are ok as well)
    Dec 2010
    Thanks Willy ! will try and report results!
    May I suggest that you backup your device before you install the new map.
