Thread: Problem with map - You canot use this map on this deice?
    j484r is offline Private
    I hope you lot had a good Christmas.
    I have a problem with my TomTom One (3rd Edition). I updated the United kingdom maps from 710.1571 to 860.3126. I have used factactivate to unlock the maps.
    App 8.10 (9369/040301) OS:100
    32MB RAM GPS 1.21 Bot 1.0012.
    I updated the navcore but suspect i've may have downloaded the wrong one because it works when i operate the tomtom via home. In the left corner shows ONE X and works just fine. However when i disconnect it throws the message that there is a problem with map and i cannot use it on this device.
    I would be very grateful if anybody provide assistance.
    macapaca's Avatar
    Norfolk UK
    166
    Re: Problem with map - You canot use this map on this deice?
    You need to patch the navcore if you use a map other than genuine.
    Use an SE navcore, its easier (I use 8.142 on this model, it always works) then all you need do is patch the map
    Thank you for that advice, i used a difference navcore as suggested and now works both the map and the application.
