Thread: tomtom speed camera
    tigger125 is offline Sergeant
    36
    tomtom speed camera
    hi i run a patched map on my tomtom one and it works fine update when i plug in to home am now thinking of putting tomtom speed cameras on it i know i have to patch the same way i did the map but will it update it self when i plug it in to home to update the map or will i need to change it now and then
    macapaca's Avatar
    Norfolk UK
    166
    Re: tomtom speed camera
    You will have to update the files manually, but if you get the latest ones they should be good for longer than they used to be, there are hardly any new cameras being installed.
    36
    cheers macapaca
