Thread: POIs not showing with 860 map
    su_A_ve's Avatar
    su_A_ve is offline Staff Sergeant
    69
    I updated my One XL-S with the latest map NA 2GB (I have an 8.4x navcore that has worked fine for the last 2 years) and noticed that my POIs are not showing up.
    They show if I select or search for them, but not while navigating. They used to in the past, but as usual with a new map, all settings go back to square one and even this time, I could not transfer my favorites as with other maps in the past.
    Any ideas what I'm missing? I have all POIs with matching OV2 and BMP (ie WalMart-NA.ov2 and WalMart-NA.bmp).
    TIA...
    macapaca's Avatar
    Norfolk UK
    166
    Re: POIs not showing with 860 map
    In the "manage POi" menu are they selected ?
    su_A_ve's Avatar
    69
    Quote Originally Posted by macapaca View Post
    Yup - Need to go now and check if I have too many selected maybe? Or is this related to the problem with the lack of the crpoi.dat file problem on the 860 maps?
