Thread: Help ASAP please. MAPS ON SD CARD
    hitman73 is offline Corporal
    27
    Question Help ASAP please. MAPS ON SD CARD
    If I copy new maps onto a sd card then insert into a tomtom will the tomtom read the new maps. The person who owns the tomtom does not want the interneal maps deleted?
    macapaca's Avatar
    Norfolk UK
    166
    Re: Help ASAP please. MAPS ON SD CARD
    If you already have a patched navcore, then all you need do is patch the map on the SD card after you insert it, then switch maps via the menu
    27
    thanks for that it has saved me a lot of space on the card thanks again
