Thread: SD Map Update help
    kmart71 is offline Corporal
    London
    28
    SD Map Update help
    Can anyone help please. I have updated my go 550 live and out a new map on an sd card, which is patched and all works. When i try to update the map it wont allow it. looking at the preerences a=it only allows changes made by Tomtom not many users. if i revert back to my old map on the device, it updates the old map fine.
    Any ideas please.
    I have UK & ROI 860.3123, Nav 9.160.
    Many thanks
    116
    Re: SD Map Update help
    What you mean when you say you cant "update the new map"?
    London
    28
    Hi, when i go into tomtom home, mapshare preferences, the slider does not move nor can i select anything (see attached) if it is a incorrect entry in the files, which one please do i change and to what.
    Many thanks
    Attached Thumbnails Attached Thumbnails SD Map Update help-map-share-preferences.jpg
