Results 1 to 8 of 8
Thread: 860 Map problem
    rugglesxzx is offline Private
    860 Map problem
    Hi
    I have a TomTom Rider 2 with the 2 GB card. I have downloaded the various Map Zones for Western & Central Europe (860.3100), patched the Navcore (version 7.901) and generated the relevant .dct file for the first map (East). When I switch on the TomTom all I get is the No Maps Found message.
    Any help would be much appreciated - what I really want to do is get a set of SD cards with each zone on so that I can easily switch while travelling between countries.
    sebastian79r's Avatar
    sebastian79r is offline Captain
    666
    59
    Re: 860 Map problem
    You must also patch the Navcore . PNDNavigator or ttsystem.
    Re: 860 Map problem
    Odd. I'd used yDGpatch to patch the Navcore and RunMeforDCT.cmd to patch the map and it didn't work. Have just used Albert's Easy Activator for both the Navcore and map and it's worked fine!
    Should have thought a bit more before posting the question, but my Go 700 for the car has always worked fine with yDGpatch and RunMeforDCT.cmd.
    Cheers
    Re: 860 Map problem
    Quote Originally Posted by yuriyggg View Post
    It's elementary Watson.
    If you can not with one tool, try using a different
    I've successfully put the East and West Europe regions on separate SD cards using Easy Activator, but I can't get South to work with either Albert's Easy Activator or yDGpatch.
    Any ideas what I can try next?
    Re: 860 Map problem
    Thanks for the quick reply. Still get the 'no maps found' for Europe South, but Europe East and Europe West work fine! Even tried a re-format and re-install of the patched Navcore.
    hobbitter is offline Private
    Re: 860 Map problem
    have you tried to update the meta file?
    Re: 860 Map problem
    Yep, have just wiped the card and re-installed everything, patched the NavCore and regenerated the meta file. All works now!! Only thing is that TomTom Home doesn't say I have the latest version of the map, just 'no information available', but it does for the West and East.
    Anywhere, all OK now.
    Re: 860 Map problem
    ; Europe_South_860_3100
    66 11 8B 53 62 3A 66 0F 71 E9 CC 8C 7B F9 2B 2F Europe_South-224.meta
    check it in the document meta
    It was correct, but all OK now, see my response to hobbiter.
    Many thanks for all the help & advice - this forum is brilliant!
