Results 1 to 7 of 7
Thread: Help! Tomtom on Chinese 2 DIN, WinCE6, 128MB - Getting "Not Enough Memory" Error.
    wildwild is offline Lance Corporal
    Jan 2011
    Hi all,
    I have been trying to get Tomtom 7.910 to work with a 7" 2 Din Chinese car GPS running Wince6 for days now. It ran OK in the WinCE 5 emulator, but was getting "Not Enough Memory" in the actual unit.
    Could anyone tell me how to overcome this error? I have tried with Setmem to 70000 but did not help
    The GPS is 128MB running WinCE 6. I think this unit has problems running TT.
    Help please.
    ropac's Avatar
    ropac is offline Staff Sergeant
    64
    30
    Re: Help! Tomtom on Chinese 2 DIN, WinCE6, 128MB - Getting "Not Enough Memory" Error.
    I can't really give you any advice, as I do not have a Wince6 unit.
    However, I have read quite a bit about this problem on Wince6, so my first question is: Have you tried the "mapsettings.cfg" trick?
    I have copied this from another forum:
    "I downloaded that win ce 5 emulator, activated the same map that i am using on the win ce 6. Then did a A - B route plan on the emulator (so it didn't need a GPS). I copied the mapsettings.cfg file into the win ce 6 device and hey presto, it worked!"
    Jan 2011
    Thanks for your reply.
    I have tried this trick already with no results
    ropac's Avatar
    64
    30
    Have you tried ver 7.450 as well?
    Jan 2011
    Not yet. Have you seen somewhere that it would work with WINCE6?
    crabber is offline Corporal
    20
    I have a Chinese GPS with WinCe6, 128 memory, I tried many many versions of Tomtom, all failed with memory error except the one posted by tarbardajun on Mobilism forum.
    It is version 7.910, it still needs an active route to start, I use a PDA with exactly the same map for my map settings file but there are emulators that will work to do this.
    ropac's Avatar
    64
    30
    Quote Originally Posted by wildwild View Post
    No, it is just that I found it less demanding than 7.910 so maybe it is worth trying.
    I have seen others that claim that they have TT 7.* running on their Wince6 units, and I don't dispute
    this for a minute. It really is all about the unit you have, because although these units all look the same
    BUT are VERY DIFFERENT with their software, rom's etc. and therefore capabilities.
    Maybe Crabber has the answer for you!
  1. 30th October 2011, 19:09
  2. 28th April 2011, 04:41
