Thread: little help needed Lane Guidance
    tigger125 is offline Sergeant
    36
    just updated my tomtom one v2 from nacore 7.9 to 9.051 and uk 860.3101 map it seem to work fine not tryed on road yet but i updated it to get Lane Guidance but am not sure its working have run a demo around the m6 area but it dont seem to show up the Lane Guidance were am i going wrong do i need to switch it on if so how
    lemonfish's Avatar
    Melbourne, Australia
    1,073
    140
    Re: little help needed Lane Guidance
    There is a setting in the menu "Show Lane images". If it is already switched on, then the menu will show "Hide Lane images" if you want to switch the Lane Guidance off.
    TomTom Tutorials & FAQ
    36
    my dont have that setting in the menu so do that mean i have the wrong nacore or map and can someone point me to the right one as the chart say thay should work
    lemonfish's Avatar
    1,073
    140
    You are using the correct map. The 860.3101 map is the full featured map which includes Lane Guidance.
    Try the 9.053 navcore... ALG will work for sure.
    36
    had the right map just had to change my navcore to 9.101 it works fine now
