Results 1 to 8 of 8
Thread: Go730 Features ?
    cool-vibes is offline Lance Corporal
    Go730 Features ?
    Hi all i have been reading on the forum for a while but this is my first post. I have a Go 730 and would like to update the map on it and mabe the navcore my question is i would like to know what feature are on the Go730 so i know what navcore to choose in order to have all the features. thx
    lemonfish's Avatar
    Melbourne, Australia
    1,073
    140
    Re: Go730 Features ?
    The latest official navcore for the GO730 will give you all the features, as long as you install the full featured map.
    Features include Cspeech, IQ routes, ALG & ASR.
    Simply install TomTom Home, run all available updates for your navcore.
    TomTom Tutorials & FAQ
    Silverhawk is offline Staff Sergeant
    79
    26
    I'm successfully running SE Navcore 9.205 on a Go730. If you want to try it here's a Hotfile link:
    SE.Navcore.9.205.547817.32mb.devices.rar - Download from hotfile.com
    I haven't tried 9.058 but intend to based on yuriyggg's recommendation.
    Buy a SD card to 4GB
    I think the best software is now 9058 (I use it)
    Map-Europe_860_3101 or 3102
    yuriyggg were you able to get the safety camera and lane guidance , text to speech working , because i am using the same setup as you are but i am using North Amecica 2GB map
    May 2011
    Hi, this link is not working. Is it possible to resend it? Thank you very much.
    May 2011
    To Silverhawk : This link: SE.Navcore.9.205.547817.32mb.devices.rar - Download from hotfile.com
    bmwdriver+'s Avatar
    bmwdriver+ is offline First Sergeant
    May 2011
    158
    Quote Originally Posted by cool-vibes View Post
    A detailed list and IMHO the best NC for a x30 can be found here:
    Best NavCore for Go x10, Go x20 and Go x30
    Go 730 + Best NavCore for Go x30, One 2nd edition + Urban Rider NC or Latest NC
    May 2011
    Quote Originally Posted by bmwdriver+ View Post
    Thanks for this as it was really helpful. I am currently running a modified version of 9.051 navcore on my 730. It runs very smoothly with no loss to the functionality. I remember certain navcores causing the dimming not to work properly in the past. I have tested the 9.051 modded version on the 720 as well and it works perfectly. Of course a 720 and 730 are the same unit just with the speech functionality turned off (although that is an easy fix).
