Thread: tt 3rd will not turn on
    mikie is offline Corporal
    27
    hi all pick up a tt one 3rd edition today..internal memory 512 mb,,[no sd slot]been charging it for the last 4 hours and it will not turn on..been holding down power botton ,pressing reset botton and still will not fire up...should it still powerup if the battery is dead...?any idea,s....thanks.
    sug172 is offline Sergeant
    London
    41
    Re: tt 3rd will not turn on
    Even with a dead battery it will start up so it's not the battery. It sounds like the green light of death (if you get a green light), common problem Usually caused by a faulty original tomtom charger, burns out some components on the circuit board, It can be repaired for around £20.
    lemonfish's Avatar
    Melbourne, Australia
    1,073
    140
    Quote Originally Posted by mikie View Post
    If your device is showing the charging light, then it should still power up while plugged in the charger.
    TomTom Tutorials & FAQ
    27
    thanks for the reply guys.was just about to buy a battery,usave me some cash...is the light of death an easy fix for me to do?.....
    London
    41
    This guy on eBay fixes them for £20, I have used him many times.
    TomTom repair service ( Green led of dead )-faulty on eBay (end time 01-Feb-11 16:52:09 GMT)
