Thread: lcd screen replacement..
    bass junkie is offline Staff Sergeant
    63
    hi - ive got a tomtom go 730..lcd is damaged, when it fires up it comes on with all funny line, you can see the menus, and see it is working as the voices work and evrything...so i thought id try and see if it would work with other working tomtom screens that i borrowed from mates tomtom units. Tried all go520,go530 and go 720...none of the lcd screens work..so im assuming i need a replacement for a go730 lcd screen ?...alllo thers tried just show a lit up blank screen..what are yr thoughts guys..?
    sug172 is offline Sergeant
    London
    41
    Re: lcd screen replacement..
    I'm not 100% sure but I thought all x20 and x30 screens were interchangable, Are you sure the ribbon connector is fully inserted as this can be quite tricky and will not work if not fully inserted and clamped down.
    63
    yes mate ..only two connections really...little power plug and a ribbon connection.....all securely fitted but like i said dont work..must be spedific screens for go 730 units..?
