Results 1 to 10 of 11
Thread: Go 930.Waiting for a valid GPS signal...
    kaspio is offline Private
    Two days lost signal.I formated tomtom go 930 and reloaded saved original copy and still no signal at all.Can not find bootloader 5.5120 to try to reinstall.Now TomTom is not picking up any GPS signal at all. What could be the issue? Any help would be greatly appreciated
    Re: Go 930.Waiting for a valid GPS signal...
    Thank you for file.Still no GPS signal at all.
    PSJFLA is offline Sergeant
    48
    37
    Just for the record,
    The bootloader can NOT be erased/removed even by reformating the device.
    Try this....Update the the TT using HOME then....Take the TT outside under the open sky....then do a "pin reset" using the opening on the bottom of the TT.
    Then leave the TT outside for a while and see if it finds the signal.
    Silverhawk is offline Staff Sergeant
    79
    26
    Is the "ephem" folder in the root directory? If so are the GPSQuickfix files in it? I had a similar problem with a Go 920. Keeping the Quickfix files current really speeded up acquisition times.
    I did update the Quickfix ,went outside under the open sky then did a "pin reset",still no signal at all from any satelite.
    Thanku you for respone.How can I reprogram bootloader?
    48
    37
    Quote Originally Posted by kaspio View Post
    Once you flash a Bootloader to your TT it is there to stay.
    There is a program that will downgrade a bootloader..it should only be used in extreme cases.
    At times when a new version of Navcore is released it " sometimes " contains a updated bootloader.
    That is a real danger when experimenting with Navcore versions NOT intended for a particular TT....it may contain a bootloader that will not work with your TT.
    There is no means to program the bootloader....you have a bootloader and that's that !
    I'm using the bootloader 5.5229 on my 930 without any problems....it's NOT the offical bootloader for a 930.
    Experimenting with the bootloader is very risky and could render your TT useless!
    Nothing to loose, now my TT without signal is useless anyway.How do I change to 5.5229?
    48
    37
    Bootloader's are VERY risky and can turn your TT into trash !
    see this thread
    http://gpsunderground.com/forum/tomt...r-version.html
    bootloader in post #1
    instructions in post #4
    sug172 is offline Sergeant
    London
    41
    I'm not an expert but I don't think the bootloader is related to your troubles, Are you sure your not missing something, Date and time correct on the device, left outside with a clear view to the south sky (If your in the northern hemisphere), no other electrical devices near (iphone, GSM tower). leave for 30 minutes. I have worked on a few hundred tomtoms and never gone from working GPS to non working.
    79
    26
    When you start your TT what exactly does it do? Does it get past the start-up screen to the map? If yes then unlikely you have a bootloader problem. If no did you run Clear Flash after reloading your system? Also, what do you currently have installed on your device (navcore, bootloader, type and version of map)?
