Thread: TT One v2 showing number in top right corner with NC 9.101_one
    Feb 2011
    Sorry - ignore this thread and look and look at similar one
    I have a TT One v2 with NC 9.101_one and Map Aus 860.3101 and have 2 Questions:
    1. On the top LEFT of the screen I have a number varies between about 38m to 62m. What does that number indicate and can I turn it off.
    2. IQ routes are disabled (not by me but by TT unit) and if I try using Loquendo Computer voices it just grinds the unit to a halt. It becomes jerky and seems to be in a constant state of catch up. Is this normal for this config and can I do anything else to tweak the system. Runs OK if I using a normal voice.
    Thanks,
    Wombat
    116
    Re: Sorry - ignore this thread and look and look at similar one
    I also have that number but i know what it means in my TT.. Its and higher measur soft... I mean, i installed something like a plugin that can indicate me how high i am from the sea level. Ever notticed that it varies for higher values when you drive up a hill or something??
    Hamish is offline Command Sergeant Major
    199
    1. Sounds like Joghurt's Height plug-in is installed - height in metres above datum (mean sea level).
    2. Sounds like insufficient memory.
    only TTS you will get working on a tomtom 32mb is vocalized TTS ( megalos topic in voices forum ) but doesnt work to well for me. plus make sure u are running in x40light emulation to work the best
