Thread: Can anyone help? tomtom go 520 uk voices and postcode not showing up?
    sehmus99 is offline Private
    Feb 2011
    just installed it to my go 520, for some reason i dont have uk voices and also i dont have postcode search??? anyone got any ideas?
    thank you
    davecmr is offline Corporal
    25
    Re: Can anyone help? tomtom go 520 uk voices and postcode not showing up?
    Are you missing the Voices & Zip folder? Or are the folders empty?
    Feb 2011
    i think im missing the actual files, anyideas were i can get them from?
    rotop is offline Sergeant
    52
    24
    ZIP codes:
    http://www.tomtom.com/updates/zipcodes/Map_865/zip.zip
    Voices:
    Create two folders in the root: ZIP and VOICES and put the files in there.
    Tim or Jane will talk to you. Voices on this forum:
    140 TomTom Voices
    You can make use of postal codes in UK and Benelux only.
