Results 1 to 10 of 10
Thread: HELP: Tomtom Go 700
    radioman is offline Private
    Manchester - UK
    HELP: Tomtom Go 700
    Hi
    Got this GO 700 s\hand off a mate at work.
    It says this:
    Western - Europe - Map V568.0
    App = 6.520 (7690/061002) O.S 1387
    Boot 4.86.
    Can anyone help me try and get it updated (maps,speed cams, core)
    Also i think that i might need software tomtom home to talk to it from pc
    TIA
    Radioman
    aerostar is offline Lance Corporal
    16
    Re: HELP: Tomtom Go 700
    Go here
    TomTom, portable GPS car navigation systems - _TomTom HOME
    and download TOMTOM home, and install.
    connect your Go to the PC and run TT home, then go to Update my device, and let it, when done you should have the latest operating system on the sat nav.
    You can then check what versions you have and then can down load the appropriate maps from the forum, and the activator.
    Manchester - UK
    Hi
    Just d\l TT Home (TomTomHOME2winlatest.exe)
    but it won't install on my laptop with os winXP
    so whats wrong ??
    Manchester - UK
    Hi
    Right i had to install a old ver (2.3.1.92) that loaded ok
    then i used the file from tomtoms site (TomTomHOME2winlatest.exe)
    and this updated to 2.8.0.2146 and that loaded ok.
    Now when i try to connect my tt go 700, tthome says "no device connected"
    i have tryed with a reset of my go 700, but that did not make it connect.
    Need some help with this
    TIA
    Radioman
    entwood is offline Corporal
    Mar 2011
    21
    I also have aTT700 .. bloody good piece of kit .. I have updated the navcore to SE9.051 (emulates an x40) and run maps 865.3245 Western Europe. the only thing you have to do "different" is to rename 2 traffic data files to get rid of the on-screen traffic .. which can't work on the 700 ..
    HTH
    Manchester - UK
    Hi
    Well i don't have any hair left now, with trying to get my tt go 700
    connected to tthome
    It just wont have it, tried 4 different pc's.
    Is there a way to do a update (navcore or maps) by taking out the hard drive
    and connecting it to a pc ?, i do have a pc with linux (mint) on it
    TIA
    Radioman
    Mar 2011
    21
    DON'T use Home to uopdate navcore/maps .. just connect to PC and view as an additional drive. Once you've cracked the navcore/map THEN you can use Home for the map corrections.
    It really is quite easy after you've done it the first time !!
    149
    23
    Any chance of a basic walkthrough for the go 700, i have done others but they all had a sd card, i dont want to end up bricking the unit as its not mine its a friends and i would like to keep him as a friend,thanks in advance.
    Mar 2011
    21
    Hi .. Don't know if you can get 9.051 from this site .. I got it on another one ...don't know if cross site links are allowed so I won't post it .. or if you can get "easytools" from here .. you need both for the navcore change.
    But this is how I did it ...
    I made a backup on the computer of the whole of the TT700
    I deleted everything EXCEPT the map folder (it takes ages to recopy the same thing .. and the DCT was already done
    I copied the whole of the downloaded 9.051 to the TT700
    I "cut" the ttsystem file from the TT700 to the folder "ttsystempatcher" in easytools.
    I ran the "runme.bat" program in systempatcher. This said the ttsytem was already patched but also made a new one ...
    I copied the "new" ttsystem to the TT700
    I switched off the TT700
    I stuck a pin in the TT700 to force a hard reset
    I started the TT700.
    It worked.
    There are a couple of extras to do if you want to run TTHome but they are dead simple as well
    To put a new map on is even easier ... download the map. delete the old map. copy the new map folder to the TT. you then need the meta txt that accompanies each map .. and you use easytools to create the new DCT ... takes about 5 minutes in total ..
    149
    23
    Thank you for your help, i managed as you described.
